rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
James_NOT_Bond
Jun 22, 2011Novice
rupert1020 wrote: Actually, it's the router that distributes the IP addresses. The WN2000RPT has an internal DHCP server which can be turned on. I had to turn mine off because it was sending out IP addresses to the attached devices which sometimes created conflicts.
See the FAQ for more information on how to turn the DHCP server on/off
http://kb.netgear.com/app/answers/detail/a_id/14239
Depending on your router you can check the ip/mac addresses from a web browser. With Netgear routers use 192.168.1.1 by default. I have a WNR3500L with dd-wrt running on it. I upgraded the original firmware on the router thinking it was the source of the problems. Although the drops are much less frequent now with dd-wrt installed, I still suspect the repeater (WN2000RPT) to be causing the drops.
usually i will always choose the official firmware instead because DD-WRT firmware is the free open-source stuff....
