rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
epalzeolithe
Jul 17, 2011Aspirant
As far as i can see, its better since i used an old 54mbps wifi router as source for the WN2000RPT,
it seems the issue is coming from the wifi N which is very unstable with my livebox 2
i don't if its the signal which is too low, or the compatibility of N standard
I still have some drop with the 54mbps, but its not so often as before
We can download the source for the firmware, so we may do a custom firmware to fix it, like auto reset if internet is dropped, or force 54mbps mode
BR
BR
