rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
FootySr
Jul 31, 2011Aspirant
kspartin wrote: What I am noticing is that the WN2000RPT is getting DHCP requests from the router for devices connected to the extender, but the router is not logging the IP addresses as in use under the Attached Devices page. I'm wondering if that can be causing a conflict?
My WNR2000v3 stopped logging IP addresses on the Attached Devices page after updating my WN2000RPT to the current 1.0.1.20 firmware today. All connections are listed on the WN2000RPT however, if it matters.
I'm not sure that particular issue is causing any effect but I've had the same issues with my WN2000RPT having to be power cycled at least once a day to get connectivity back both before and after the 1.0.1.20 WN2000RPT firmware update I mentioned above.
I'm in a different boat here as I've only just updated my home network with new Netgear options in the last week and it's not to late to return them. That said, I'd love to see a fix for this particular issue so I can go about not dealing with a network that should be running smooth enough not to have to think about. ;)
