rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
Daedalus01
Oct 10, 2011Aspirant
Static IPs is no block to attacks. If devices support it, i recommend WPA2, or WPA2-Ent if you can wing it.
shakows wrote: All the devices of my WN2000RPT have there addresses statically assigned I am not using WEP, if you do you might as well have no security at all, takes no more then 30 minutes to break into
