rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
carlton
Oct 28, 2011Aspirant
DaniT wrote: Hi everyone, just registered to say +1 on this topic.
I've been experiencing the same issue you report. The connection drops in a max of 9 hours so i have to constantly reset the repeater, useless. I've tried all the suggestions (hidden dhcp server, fixed ip, changed channels, updated firmware), i use no encryption so no problem there (i live in the countryside), so i can't seem to find any solution.
Any new idea on this? some beta firmware to try or anything? Assume the loss, throw it out and buy something else?
Thanks!
Hello,
To be totally honest i would take the wn2000rpt back and buy a different brand. I tried everything as well and mine is still very unreliable. mine works for about 2 days before it craps out so its bearable.
Goodluck.
