rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
Matazal
Nov 26, 2011Aspirant
I had the same problem, frequent disconnection from the internet while i stayed connected to the network.
I made this account to let everyone know that the fix i tried has worked and it has not disconnected for 3 days now.
here is what i did:
1.Set a static IP for the extender
2.Set a static IP for my computer
to set the static IP for extender you go to the mywifiext.com and under setup there is IP setting and choose static IP
to set your computer static IP you go to the network adaptor setting and change it from there, should be familiar with it by now try to solve the problem.
Hope this helps!
here is what i did:
Hope this helps!
