rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
Mudder
Dec 10, 2011Aspirant
I have the same issue as many other posters. I've had the extender about a month. First time I plugged it up it worked fine, but eventually switched to red. I reconfigured my existing setup to enable it to get a stronger signal and now i am unable to connect to the internet through it at all. If I even attempt to use it wirelessly or wired, it immediately goes from green to red and will not let me do anything. I can't even update the firmware to attempt that resolution. I'm not nearly as computer savvy as many of the previous posters, but I am anxiously awaiting a resolution.
