rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
pli
Jan 16, 2012Aspirant
Problem solved!
Thanx to Netgear support.
It was not so difficult when you know how to do.
Go to a computer shop and buy new equipment. In my case an ASUS RT-N56U.
I replaced my WNR3500L with the new ASUS router. Installed DD-WRT on the WNR3500L and configured it as a (in my case) Client Bridge. Replaced the WN2000RPT with my "new" bridge.
Then finaly: Problem solved.
The WN200RPT can you put in a trash can or a dark closet. (The closet if you think that Netgear will solve the problem some day.)
Ok, I will be honest.
Netgear support confirms stability problems with the WN2000RPT.
They told me: "A product that I think is more stable is wn3000rp".
Do they think I will buy a WN3000RP when they can't solve the problem with the WN2000RPT?
