rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
srjpphilly
Jan 19, 2012Novice
did two things and it worked again
went into configuration for extender and changed security to wpa-psk + wpa2-psk (bottom one) it had been wpa tkip which was set from the wizard, the router seems to be both g & n, which was noted n another thread
before that i went to my primary router (actiontec) and restricted the dhcp range and set up the extended with a static ip (252) outside of the dynamic range
