rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
ansch07780
Jan 24, 2012Novice
I have had this issue for months. It has been so irritating that I figured I must have done something wrong. I have reset my router more times than I can count and tried every setting under the sun. I finally looked on the Netgear forums and found this thread. I can not believe so many are having this issue and it is not being addressed by NetGear. If a resolution is not forthcoming ASAP from NetGear, I will purchase another Router and another repeater. Then NetGear will go the way other bad vendors have treated me, to the garbage never to purchase from them again!
