rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
Ripcurlsurf
Feb 05, 2012Novice
I have fixed the issue.
This is what I did and its possiable either/all contributed to it.
Firstly I backdated the firmware to 1.0.0.2 and reset - http://tinyurl.com/7feemjh
I reset my wifi names on both Wn2000rpt and my belkim to names and numbers only. I removed spaces and underscores.
I moved my Netcomm router so the signal strength maintained above 50%.
The router has a constant red light (flaw from the original firmware) on but the signal strenth and no drop outs after 2 days. Whereas it was so consistent before.
Give it a try and let me know if this works for you.
