rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
H3LP
Feb 16, 2012Aspirant
Cooperman123 wrote: I've had my WN2000RPT for 6 months and I get the same problem too.
The wireless strength light seems to rotate through the Amber/Green/Red sequence consistently for no apparent reason. Sometimes I can access the internet through it and sometimes not.
I've tried the fixed IP, reboot, different security settings (WPA, WEP) nothing seems to make any difference.
Has anyone found a solution to this problem yet ?
Hi there! So I posted a possible solution to this same problem about a month back and I would like to confirm that it has worked. Ever since I changed my main router settings, I have not had a single drop with this extender. If you have not checked it out, I recommend looking at my post. I believe it is on page 13 of this thread. Hope it helps
