rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
vinceroebuck
Mar 14, 2012Apprentice
Guys, i know this is frustrating but hang in there. what i did was set up static ips for all my system. thats 15 total. you do that in the main router. the wn2000rpt is set up with static ip. the main router is say 192.168.1.1 and the wn2000 static ip is 192.168.1.100. in the wn2000 i turned off dhcp. google turning off dhcp in wn2000rpt and its in there. its a hidden command in the login that is not visible for some strange reason!! i am not a techno geek, but like they say, patience. good luck
