rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I c...
standDown
Mar 15, 2012Aspirant
Had this problem for a while. First the repeater kept dropping the signal and then it was no internet at all. For me the fix was
1. disable dhcp on the repeater.
2. give the repeater a static ip address.
3. unchecked the check for new version upon login under firmware upgrade.
4. roll the firmware back to the initial release version 1.0.0.2. (download it from here to your desktop. then upload it to the repeater.
After that i have a steady connection and i can access the internet.
Good luck it's been very frustrating but my problems are solved!
