rpz620
Nov 09, 2010Aspirant
WN2000RPT - Internet Access Keeps Dropping
All of my devices can continually access the WN2000RPT device and access the local network as well as the internet. However, after some time, the internet connection drops for the repeater only - I can still access the local network but not the internet.
Is there a timeout or something that would cause it to lose it's connection? Seems that bouncing the repeater works, albeit temporarily.
thanks.
Ryan
thanks.
Ryan
- glinggloNoviceHi Guys,
I had the same problem. I thought I will throw it in the thrash. But finally I found solution. For first: I had this problem mainly during movie playback from my Synology NAS (NFS). Solution was/is Port Forwarding: I added manually all relevant NFS port (111, 2049, 892) in my Netgear Router (WNDR 3700 - port forwarding category) for the NAS IP. And now all is smooth without the interrupting for about 4 months :) So try to add your protocol ports in the port forwarding option of your router. - x0aInitiateI've installed DD-WRT on this router (alternative firmware for those who don't know) and I still have a problem with internet access dropping. Usually after a day of stable connection.
Specifically, the router completely freezes for about a minute at a time (completely unresponsive, even the configuration page/pings hang). Eventually it'll unfreeze and internet connectivity will resume. Until it freezes again. Usually physically rebooting the router staves off disconnection problems for about a day til it starts hanging again. And once it starts doing that, it'll continue to do it every 5 minutes or so until I physically restart it. Sometimes (but not always), soft rebooting (through the firmware) fixes the problem too.
I'm guessing that netgear's firmware deals with this apparent freezing by automatically rebooting the router (which is why the lights flash for most of you when this happens).
Turns out that DD-WRT developers have had trouble with this "bug" for YEARS and they still haven't figured it out, in addition to a few other Netgear routers.
This leads me to believe that the problem is hardware and not software.
