CaptainNemo
Jul 17, 2011Aspirant
WN2000RPT :: Cannot enter PSK Key
Hi I've started with the installation of my WN2000RPT to extend my WLAN. I use a WPA/WPA2-PSK encryption. The Netgear does find the network but it seems that the passkey is no accepted - nothing h...
idxpired
Jul 18, 2011Guide
very common error with all wn2000rpt
u will have to manually enter all the setings of your router
when u run the setup wizard
it scanns and tells the network available
in place of selecting urs
click manually enter or manually input which is the last choice
then enter the name as ur router's wireless is . make sure that its case sensitive and has to be exactly the same
tehn enter the security type , u can come to know the security type from the very screen where u get stuck, where u cannot proceed after entering ur passphrase or key
see which security type u have, then the last is enter the passphrase in the manual input method and do the setup
good to go
good to go
