Ian_NZ
Aug 30, 2011Aspirant
WN2000RPT & iPad
I have been following the thread on internet dropping out on this device but have a different problem. I set up the WN2000RPT extender using the wizard and all looked good. My iPad connected with a st...
Ian_NZ
Aug 31, 2011Aspirant
Almost immediately after my post I solved the problem. The logic of how totally escapes me. I made the post from my PC right next to my Belkin router. I then connected the iPad to the extender even though the signal was very weak. When I took the iPad to the other end of the house it stayed connected with the Internet working.
The iPad still drops the Internet but not as often as when I had a weak signal.
This is a well documented iPad problem, hopefully iOS 5 will fix it.
