mikeswim07
Jul 11, 2012Follower
WN2000RPT and Xbox live
Hi, I recently purchased a Netgear Universal WiFi Range extender. I set it up and it seems to work fine for connecting to the internet. But, I am unable to connect to xbox live through the wireless...
reisendegringo
Oct 14, 2012Aspirant
I'm having the same problem, my son's XBox cannot connect to XBox Live when hardwired to the range extender. I can, however, connect to the net wirelessly via the extender using a PC, idevice, and Kindle. If, however, I try to use an ethernet cable, and a PC, I end up with a password prompt and the admin page of the extender. I suspect that the XBox is receiving the same request.
I ended up buying an XBox wireless adapter, (which took some doing as none of the stores here in Norway carry accessories for earlier XBox 360 models without built-in wifi).
