czim
Sep 02, 2011Novice
WN2000RPT cannot update firmware
To connect to the nex Freebox, I was told by the support to update the firmware. I downloaded the firmware, but cannot find where to clic on the Netgear interface to do the update. Ther should be a ...
jmizoguchi
Sep 03, 2011Virtuoso
Make sure you have setup your extender before you try to upgrade the device
