sandroxxxx
Feb 16, 2021Follower
WN2000RPT EXT
Hello, after several attempts to update the firmware and reset behind the equipment, I still have a single light flashing in front of the equipment. try to update the firmware with tftp to the la...
Feb 16, 2021Guru - Experienced User
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
