TMD
Nov 27, 2013Follower
WN2000RPT Internet Connection Issues
Hi, I hope someone can help me out with this. I've set up the extender via web (wireless) without a problem and it says _EXT is connected to the internet, however web pages are unavailable when I g...
jkmctee
Dec 11, 2013Aspirant
I originally tried the quick set up but had no luck. The repeater said it was connected to the router but the repeater would not accept the security key/password when I tried to connect other devices to it. On to Option 2 (manually). Support told me I was not doing the factory reset correctly. You need to hold the reset button in for a 30 count and then unplug it for another 30 seconds. Once I did that and plugged it back in, I was able to connect to the repeater with my iphone and mywifiext came right up. Followed the setup steps and I was done. Works great! Took 10 minutes.
