shogo2040
Sep 10, 2011Novice
WN2000RPT is slower than WNR3500L
WN2000RPT is connected via wifi to WNR3500L. WNR3500L is upstairs, and WN2000RPT is downstairs, using WPA-PSK. I'm downstairs with my laptop and connect to WNR3500L via wifi and run speedtest.net...
shogo2040
Sep 12, 2011Novice
jmizoguchi wrote: did you test with pc wired the lan ports of extender or connect to extender with wifi?
test both ways
That was for extender with wifi. So now I justed tested my laptop connected via ethernet to the lan ports of the extender. Wow, the lag is gone?? Its fast! Its 23 meg down ; 4 meg up. I don't get it. Hmm.. should I try changing my wifi channels on my extender since the extender wifi is the one with lag? Any other wifi configs I should try on my extender?
