shogo2040
Sep 10, 2011Novice
WN2000RPT is slower than WNR3500L
WN2000RPT is connected via wifi to WNR3500L. WNR3500L is upstairs, and WN2000RPT is downstairs, using WPA-PSK. I'm downstairs with my laptop and connect to WNR3500L via wifi and run speedtest.net...
jmizoguchi
Sep 12, 2011Virtuoso
same answer here... from the SSID extender signal you will loose 50% of 9Mbps is not exact half but correctly showing for wifi while the pc suing ethernet showing 23Mbps
