grogger
Oct 27, 2011Follower
WN2000RPT newbie questions
So I just bought a Netgear WN2000RPT to extend my wifi in my house. Here is the situation...I have a dlink DIR-615 wireless router downstairs and i have networked it to the WN2000RPT. I have the lig...
jmizoguchi
Oct 27, 2011Virtuoso
1. When I press the WPS button ((not sure if I need to) the light doesn't going on and never flashes.
WPS will only work if main router support WPS.
use encryption that to connect to main router instead. setup guides has BOTH setups procedure
2. I can't access the www.mywifiext.net webside.
http://support.netgear.com/app/answers/detail/a_id/14239
