bpbyrne
Jul 11, 2011Follower
WN2000RPT requires restarts
Hi - I have managed to setup my WN2000RPT as follows: - Updated firmware to *.20 (nothing worked until I did) - Dynamic IP - WPA2 Security - Connected (also through Dynamic IP) to my wireless r...
igorsetas
Nov 27, 2011Tutor
Hello,
Wifi connection problem that is lost after a while ....
I have 3 WN2000RPT throughout the house and have a problem of lost WIFI connection.
The WN2000RPT that is connected to the ISP via WIFI Router, after 1-4 hours, and sometimes can be 1 day, loses connection with the WIFI Router ISP.
Entertained with the other two this is not happening.
After several tests and many wasted hours trying to solve the problem, I made an update to the latest version of fireware (V1.0.1.20) and the problem remains.
The distance between the ISP router is 3 meters and the percentage is 100%.
The channel I'm using right now is the 4 channel because this channel does not have any more available network.
If you use channel 1, 7 or 13, I have a lot of interference and breaks the connection because there are many routers to use these channels.
Using the connection channel 4 is more than four hours but more than 2 days EVER.
Even using other devices to reduce interference, my problem remains, and it seems that the only or not. The repeater after a certain time loses connection with the wireless router from your ISP, and this is what is my main problem. I remember that I have two other repeaters WN2000RPT with the latest version of fireware (V1.0.1.20) and do not lose wireless connection when connected to the ISP Router.
What can I do more? Anyone know of any resolution?
The link to the fireware V.1.0.1.26 which provided for WN2000RPT is off. Can you give me the link to the fireware.O WN2000RPT I have is the European version.
:mad: :confused: :(
:mad: :confused: :(
