krissych
Oct 18, 2012Follower
WN2000RPT Says Connected But No Internet
I have to reset the adapter constantly and unplug and plug in my router all the time for the internet to work. When I unplug the router and plug it back in, it tells me that it is a self assigned ip a...
pinkbytes
Oct 22, 2012Aspirant
If your laptop is connected to the wireless network of your router, are you able to go online?
If you are able to go online wirelessly when you are connected on your router wireless network try to follow the instructions below:
1. Reconfigure the extender within the same room of your router.
2. Make sure Power switch is set to ON. Then wait for Extender LED status to be green.
3. Using a paper clip or a pin please press and hold the reset button at the back of the extender for about 30 seconds.
4. Unplug the power cable for 5 sec. then plug it back again.
5. On a wireless PC, connect to NETGEAR_EXT SSID then Select ‘Connect Anyway’.
Note: Default SSID of WN2000RPT is NETGEAR_EXT.
6. After successfully connecting to NETGEAR_EXT, click ‘Close’.
7. Open a web browser to start the Smart Wizard. On the address bar type www.mywifiext.net or www.mywifiext.com or http://192.168.1.250.
8. Click ‘Continue’ to start detecting wireless networks.
9. Select your wireless network to connect the WN2000RPT and click ‘Continue.
10. Enter Passphrase/network key of the wireless network that you want to connect and click ‘Continue’.
For WEP: You have to type your password on Key 1 box.
11. For the wireless settings of your NETGEAR WN2000RPT, accept the default by clicking ‘Continue’.
NOTE: Unchecking the “Use the same security and passphrase as those for the existing network” will allow you to configure Extender’s wireless security.
12. WN2000RPT will try to connect to wireless network. Click ‘OK’ and connect a wireless device to the WN2000RPT.
13. Do not click the “I have connected to the extender network “until you have connected one of your wireless PC.
14. Minimized the NETGEAR smart wizard page, then on your wireless computer, scan for the new SSID of WN2000RPT.
15. If a window prompts you to do WPS push button method, click on “I want to enter the network key or passphrase instead” to manually enter the wireless security to the wireless computer.
16. Enter the security key or passphrase. (key 1)
17. Wireless computer will start to connect to WN2000RPT. Once connected, click on Close.
18. Go back to the NETGEAR smart wizard page. Click “I have connected to the Extender network”. Then “Finish”.
NOTE: There will be a configuration page option after installation that will allow you to save the Configuration Page on your Bookmarks.
You may now connect your wireless device to the extender network and check if you can now access the Internet.
