krissych
Oct 18, 2012Follower
WN2000RPT Says Connected But No Internet
I have to reset the adapter constantly and unplug and plug in my router all the time for the internet to work. When I unplug the router and plug it back in, it tells me that it is a self assigned ip a...
asrtaylor
Nov 08, 2012Aspirant
I have the same issue, and tried all the steps above, with no resolution. Although I can connect to the device with any of the 5 devices I've tried, they all indicate no Internet access. I do get an IP from the device, so it's kind of alive. I also get 404 errors if I try www.mywifiext.net or www.mywifiext.com or http://my dhcp address from wired router.
So far, only power off / on seems to make the issue go away for a day.
Any other suggestions?
