itfidds
May 03, 2013Aspirant
WN2000RPT unable to change region
Hi, I have a WN2000RPT which originally had firmware V1.0.1.20NA and, as I am in Spain I upgraded the firmware to V1.0.1.24 and reset the router. When I try to configure the region it is greyed ...
itfidds
May 07, 2013Aspirant
Hi,
I notice that this problem has had lots of views but, as yet, no suggestions.
Is it because that this is a known problem that cannot be fixed or is it that no-one has come across it before?
So far I have updated to V1.0.1.24 with no success. I have also re-flashed with the original release firmware V1.0.0.2 and then upgraded the firmware and language file to the latest editions.
I have now changed my adsl router to channel 3 and am able to connect the extender. This allows me partial access to the internet but it is extremely slow and and times out on updates to AV software, MS updates etc.
In addition I still cannot change the region from United States.
I have borrowed a TP-Link extender and that worked out of the box.
Any ideas? Anything please...
Thanks in advance.
Thanks in advance.
