jkmctee
Dec 10, 2013Aspirant
WN2000rpt v2 Set Up Instructions
Ok so the quick recommended set up (Option 1) is to turn on the repeater, wait a minute, get the green light, press WPS. Then within 2 minutes press WPS on your router. Voila! Pressing the WPS bu...
WizardJ
Dec 10, 2013Luminary
I have the WN2000RPTv2 here at home myself. When you have done a factory reset on it (by pushing and holding the "Restore Factory Settings" hole on the back, for let's say 20 seconds) and the middle LED is green, you should be able to find "NETGEAR_EXT" as a wireless network on your computer. Connect to that and then try to reach any webpage and you should be directed directly to an installation guide of the extender. Give that a go.
If that doesn't work, I suggest you have a talk with Netgear support as the forums are user-to-user only. No need to break anything. :)
