jkmctee
Dec 10, 2013Aspirant
WN2000rpt v2 Set Up Instructions
Ok so the quick recommended set up (Option 1) is to turn on the repeater, wait a minute, get the green light, press WPS. Then within 2 minutes press WPS on your router. Voila! Pressing the WPS bu...
jkmctee
Dec 11, 2013Aspirant
Thanks Wizard. The issue was the factory reset. Once I did that correctly I was able to get it going as it was supposed to. So the support guy said to hold the button for 30 seconds and then unplug the unit for 30 seconds as well. Worked great!
