jkmctee
Dec 10, 2013Aspirant
WN2000rpt v2 Set Up Instructions
Ok so the quick recommended set up (Option 1) is to turn on the repeater, wait a minute, get the green light, press WPS. Then within 2 minutes press WPS on your router. Voila! Pressing the WPS bu...
oldman1943
Jun 13, 2014Aspirant
I have the same router extender. I can connect to the router extender and bring up the netgear genie. Problem 1 it does not see my network name, so I used the manual method. By the way my wifi network is up and running withe three computers. I then followed the instructions. When I got to the last step I finalized the proccess and it said to connect my device I did . The it jumped right back to the first step. I tried to ping it failed and it would not connect to the network.
If someone could help please as I need to install this for access from outside.
Thanks inadvance
Thanks inadvance
