TOPTRUK
Dec 11, 2014Novice
WN2000RPT WiFi Rang Extender Hard Wired?
I was told by the Best Buy employee that I could hard wire (with an Ethernet cord) from the current router I have in the house (WNR2000) to the WiFi extender in any of the ports on the back to boost t...
fordem
Dec 12, 2014Mentor
You really need to decide what functionality you need - you asked for WiFi in the barn - since you already have a cable run out to the barn, I would suggest a network switch to allow for other wired devices, along with the access point or extender.
As far as getting another router - personally, I feel that multiple routers in a single network should be avoided like the plague, but more & more of today's consumer routers have an "AP" mode that allows them to be used as an access point, so I've stopped telling people that - although - I will state that generally speaking, it is not a good idea unless you have a very good grasp of networking.
For what it's worth - the EX6100 also has routing capabilities - if routing capability is what you need.
