JasonGibbs
Sep 03, 2011Novice
WN2000RPT with Android and iPhone problem
Just got a WN2000RPT. Set it up just fine. I can connect great with 2 different laptops (both running Windows 7)...HOWEVER, my phones don't work. I have an android and an iphone. Both of them have...
JasonGibbs
Sep 04, 2011Novice
jmizoguchi wrote: Have you test with out with public DNS on phone side?
Hm..not sure what you mean. If I'm directly entering IP addresses for local machines (i.e., it shouldn't even route outside the home network) then DNS shouldn't have anything to do with it, right?
But either way, the DHCP gives out my local router (192.168.0.1) as the primary DNS. (And yes, I have DNS running on the local router. It's a Netgear WNR3500L/U/v2 running Tomato 1.28)
