rcola
Sep 25, 2012Aspirant
WN2000RPTv1 WN2000RPTv2
Hi all,
could anyone tell me the difference between WN2000RPTv1 and WN2000RPTv2?
I would like to buy WN2000RPT from Amazon but the version is not specified.
I will you it to connect the actual wireless network to the TV, PS3 via ethernet.
Thanks a lot.
Richard
Thanks a lot.
Richard
- rcolaAspirantSorry I've opened twice. It can be closed. Richard
- plowe2AspirantHi,
I have just bought a refurbished WN2000RPT bt it does not state which version it is so
Which version of the software can I use
v1
or
v2
Txs
Peter - jmizoguchiVirtuosoIf not listed at label of the then it is v1
ONLY v2 up will showing the label after the model number
