barisad
Oct 17, 2014Aspirant
WN2000RPTv2 causing my survelience monitor/dvr to restart
Hoping the title is a start? We stay in a campground with WIFI. We needed to install a survelience system. The only way to be able to remotely view the camera (needed an Ethernet port). Was to al...
fordem
Oct 17, 2014Mentor
The situation as you describe it would be VERY unusual - so unusual in fact, that I would have to see it in person to believe it.
How a particular camera is connected would/should have no impact on the DVR/monitor shutting off - I could see it preventing recording (if there is no signal there is nothing to record), so that might explain voids in the recording time, but not a shut off & restart scenario.
The systems I've worked with all support multiple cameras and if a particular camera is disabled or disconnected, the DVR continues to run and record the video from the remaining cameras.
Maybe you could observe a little more closely - is the DVR actually restarting - if it is, I would check the power to the DVR, and then contact the manufacturer.
