abeagley
Apr 03, 2012Follower
WN2000RPTv2 Connecting To Wireless Network But No Internet
I recently purchased a WN2000RPTv2 to extend the wireless in my house. I've ran through the setup multiple times with multiple browsers (IE, Firefox, and Safari). Each time it properly detects my home...
Jeffrey07
Apr 11, 2012Novice
I suggest you try to reset the WN2000RPTv2 and run the setup using the setup wizard. When you get to the wizard, use the manually input SSID. Make sure you enter the exact settings you have from the main wireless router.
