optodata
Aug 22, 2012Aspirant
WN2000RPTv2 connection issues
I'm having trouble reaching the internet through a WN2000RPTv2. It has the latest firmware (1.1.0.12) and my Win7x64 laptop shows internet connectivity and Home Group access, but I cannot reach any we...
NoXoZ
Sep 03, 2012Aspirant
milrose wrote: I thought this would be easy. mywifiext.net is mythical. Doesn't exist. Not sure why that website is even listed in the installation guide. I can get the extender to work but 3 weeks of trying to get it secure has failed. The netgear genie shows up (only one time and it too has gone by the wayside) but I can get about halfway through the setup and it freezes and then quits. I'm on an iMac but have also tried using windoze.
I'm trying 1 more day and then I'm switching to another brand. 3 weeks of trying has taken it's toll.
Try to reset your extender first. Then connect your computer directly to your extender using a cable instead of connecting to the default wireless SSID of the extender. Follow the steps to setup the extender again.
To the topic starter, you should try placing your extender on the same room where your router is for isolation. You may have to do the same thing that I have mentioned above to setup the extender. Please check if your computers really gets the Internet connection when they are connected to the wireless network of the router.
