DRWAYNE's avatar
DRWAYNE
WN2000RPTv2 Extender with WNDR3700v2
I purchased a WN2000PRTv2 Extender to use with a WNDR3700v2 Router for a unique application. Router is located in the tower of a local race track where the wireless signal is sent to a printer some 600 feet away. Problem was before getting the extender sometimes it worked fine other times signal was too weak at the printer end. I located the extender half way between the tower and printer but still the signal is weak and extender signal indicator will show green or yellow to red. Is there an extender with more power with could be a better solution for this problem?
