randjoe's avatar
randjoe
Follower
Aug 27, 2012
wn2000rptv2 setup loop
I have setup another netgear extender(different model) before using the smart wizard and its worked fine. After I could get to the advanced settings through mywifiext.com and the network/internet access worked.
With the wn2000rptv2, I go to mywifiext.com and complete the smart wizard, straight after it goes to mywifiext.net and shows the smart wizard again. So I completed the smart wizard again(on .net) and it goes back to mywifiext.com and so on.
Ive tried a factory reset, but it still stuck in smart wizard loop.
Not sure what next to try.
1 Reply
  • Randjoe, they r one of the same site. As u complete the smart wizard setup configuration, for some reason it switches from mywifiext.net to mywifiext.com by the time the smart wizard ask u about firmware updates. Dont let that throw u...continue the process. U should be fine if u have made it to that point in the configuration. Some customer cant even connection to site.
