Pnut717
May 16, 2013Follower
WN2000RPTv2-WiFi Range Extender
I hope I am doing this right. I have very little experience with forums. How do I find out what channel my repeater is on? Does it have to be on a different channel from my WNR1000v2 router/Wireles...
McGrats
May 17, 2013Aspirant
I just installed one of the WN2000RPT with a N300 wireless router. To the best of my knowledge, there is nothing to access in the WN2000 since it merely reflects everything in the actual router.
I found it was better to setup the 2000 using option 2 (the manual method), and if you are installing it with a Comcast modem, you have additional steps to do in order for it to work.
Hope this helps. :)
Hope this helps. :)
