Pnut717
May 16, 2013Follower
WN2000RPTv2-WiFi Range Extender
I hope I am doing this right. I have very little experience with forums. How do I find out what channel my repeater is on? Does it have to be on a different channel from my WNR1000v2 router/Wireles...
jfinn33
Jun 26, 2013Aspirant
This is my first time on these forums, and I couldn't find where to post a new thread. So here it goes. I manage 22 timeshare condo's that are spread out in a residential neighborhood. In order to obtain wireless internet for my guests, my internet services guy recommended Meraki OD2 repeaters to be installed on the exterior buildings and repeating the signal down the road. THEN he said we needed Intellinet 300 brand Access Points to get the signal inside our units. THEN I purchased 18 Netgear WiFI Range Extenders, Model # WN2000RPT to boost the signal inside the units, because without these the guests got limited WiFi access. (sigh).
Since installation, we've had several connectivity and dropping signal problems. I am a tried and true Netgear fan, and truly believe the range extenders are NOT the problem. However, my Internet Services guy says that he believes it's the Netgears that are causing numerous issues. I can't seem to find an answer on Cisco's website (Meraki units) OR the Intellinet site. I am hoping that someone here can help me. I don't know if there is a communication breakdown between the 3 devices or if it's actually the netgears that are causing the issue. Any help would be greatly appreciated.
Thank you,
PS: This is what my internet guy tells me: "It appears that the Netgear Range Extenders that are connecting to the Intellinet AP's which are plugged into the OD2's are still causing the OD2's to lose connection with the router.":confused:
Thank you,
