Bancey
Jul 22, 2012Follower
WN2000RPTv2 Xbox Live Connection Problems?
Hello All!
I recently purchased a WN2000RPPTv2 Wirelss range extender for my room as I get very bad signal from my router.
I manged to get it up a running fairly easily and all my devices apart from my xbox. My xbox cannot connect to it allthough I am sure that I gave it the right password (I have tried over 10 times) So I have turned here to see If someone has had the same problem and might be able to help :)
All help is appreciated.
-Bancey
-Bancey
1 Reply
- jmizoguchiVirtuosomake sure you are using WPA2
