jissa
Sep 19, 2011Follower
WN200RPT Bridge Performance
I have a WN2000RPT range extender that I am using as a wireless bridge to connect wired devices upstairs to the Internet. My main router is a linksys WRT54G. I was able to bridge the connection with n...
jmizoguchi
Sep 19, 2011Virtuoso
if you have player using ethernet to the wn2000rpt you should get too throughput. BUT if you use wireless connecting to _ext SSID , extender wireless then you will loose 50% throughput. this nature of repeating on _ext SSID
