koke4716
Jul 09, 2011Aspirant
WN200RPT Range Extender - Amber Status Light
I have a a WN2000RPT Range Extender which has been working fine until last night when I could not connect. My wireless NIC saw the WN2000RPT but could not connect to it. I unplugged the Extender...
Snowybunting
Mar 12, 2012Aspirant
I'm having the exact same issue. The status light stays amber, which the guide says means the wireless connection is only "good", although I've moved it right next to the main router. I can't get it to reset to factory default, and can't connect via browser. The router sees the device, but it hasn't assigned it an ip address. It's basically a brick right now.
