Mark_T_H
Oct 10, 2018Tutor
WN2500RP firmware update broke WiFi connectivity
After performing WN2500RP firmware update, the device is no longer visible on the network and is no longer accessable via WiFi. The Range Extender device does turn on with green power and Wi...
DexterJB
Oct 18, 2018NETGEAR Moderator
Hi Mark_T_H,
Welcome to the community!
We recommend doing a factory reset after the firmware update.
Dexter
Community Team
- DexterJBOct 21, 2018NETGEAR Moderator
Hi Mark_T_H,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team- Mark_T_HOct 22, 2018Tutor
Restore to Factory Settings did not help. The Wi-Fi Indicator is still dark and the device is not visible on the network.
- DexterJBOct 23, 2018NETGEAR Moderator
- Mark_T_HOct 23, 2018Tutor
Okay, thanks for sending a message to my inbox. I don't see anything here in the NetGear Community inbox other than the message that says you sent me one. I checked my company e-mail inbox, and there's nothing there other than one message that says Dexter sent me a private message and another that says Dexter mentioned me in a post(!).
Maybe I'm moving faster than the internet is, or messages are moving at snail-mail speed. Either way, I'm looking forward to some help to get our range extender functional again...
Thanks,
-Mark
