Mark_T_H
Oct 10, 2018Tutor
WN2500RP firmware update broke WiFi connectivity
After performing WN2500RP firmware update, the device is no longer visible on the network and is no longer accessable via WiFi. The Range Extender device does turn on with green power and Wi...
DexterJB
Oct 21, 2018NETGEAR Moderator
Hi Mark_T_H,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
Mark_T_H
Oct 22, 2018Tutor
Restore to Factory Settings did not help. The Wi-Fi Indicator is still dark and the device is not visible on the network.
