Mark_T_H
Oct 10, 2018Tutor
WN2500RP firmware update broke WiFi connectivity
After performing WN2500RP firmware update, the device is no longer visible on the network and is no longer accessable via WiFi. The Range Extender device does turn on with green power and Wi...
DexterJB
Oct 23, 2018NETGEAR Moderator
Mark_T_H
Oct 23, 2018Tutor
Okay, thanks for sending a message to my inbox. I don't see anything here in the NetGear Community inbox other than the message that says you sent me one. I checked my company e-mail inbox, and there's nothing there other than one message that says Dexter sent me a private message and another that says Dexter mentioned me in a post(!).
Maybe I'm moving faster than the internet is, or messages are moving at snail-mail speed. Either way, I'm looking forward to some help to get our range extender functional again...
Thanks,
-Mark
- StephenBOct 27, 2018Guru - Experienced User
There is an envelope icon in the upper right of the forum (next to your username). Click on that, and you will get into the private message facility.
