Southcanuck
Jan 02, 2021Follower
WN2500RP not connecting to internet but connects to router
I recently upgraded my Xfinity Comcast router from 200 MBPS to a new router with 1000 MBPS and I also have Ring doorbells and camers. The front door is on the Ring doorbell which worked fine before ...
Jan 02, 2021Guru - Experienced User
which comcast router is it?
During install of the extenders, did you setup using WPS? If so, factory reset the extenders and reinstall them using the installation assistant.
- NippalzJun 15, 2021Aspirant
I have this exact same issue. Used the installer to connect to the wifi. Connects and shows zero service. Any updates? Firmware is also updated
plemans wrote:which comcast router is it?
- entfishOct 21, 2021Aspirant
I have the same problem. It's driving me nuts. I'm disgusted that Netgear won't help without payment!
What is the "installation assistant" and how do I access it?
- plemansOct 21, 2021Guru - Experienced User
entfish factory reset your extender. Then starting from stock use the assistant. I linked to the video of how to use it.
How to Setup your WiFi Range Extender with NETGEAR Installation Assistant - YouTube
If that doesn't help, please start your own thread. thanks
