Southcanuck
Jan 02, 2021Follower
WN2500RP not connecting to internet but connects to router
I recently upgraded my Xfinity Comcast router from 200 MBPS to a new router with 1000 MBPS and I also have Ring doorbells and camers. The front door is on the Ring doorbell which worked fine before ...
Jan 02, 2021Guru - Experienced User
which comcast router is it?
During install of the extenders, did you setup using WPS? If so, factory reset the extenders and reinstall them using the installation assistant.
Nippalz
Jun 15, 2021Aspirant
I have this exact same issue. Used the installer to connect to the wifi. Connects and shows zero service. Any updates? Firmware is also updated
plemans wrote:which comcast router is it?
