Southcanuck
Jan 02, 2021Follower
WN2500RP not connecting to internet but connects to router
I recently upgraded my Xfinity Comcast router from 200 MBPS to a new router with 1000 MBPS and I also have Ring doorbells and camers. The front door is on the Ring doorbell which worked fine before ...
Nippalz
Jun 15, 2021Aspirant
I have this exact same issue. Used the installer to connect to the wifi. Connects and shows zero service. Any updates? Firmware is also updated
plemans wrote:which comcast router is it?
During install of the extenders, did you setup using WPS? If so, factory reset the extenders and reinstall them using the installation assistant.
